Sensor PING Parallax
let me ask all...
has anyone ever made a program to adjust the water level using the PID method using myrio? If there is please help 🙏
 Thank you for your attention
(2,856 Views)
Hey, Nimass
probably a lot of people here has done a PID controller,
also communicated PING sensor with myRIO
and done PID with myRIO.
you need to share more information. What is your difficulty? is it the sensor? is it the PID? is it myRIO?
What have you already done?
Is that your homework and perhaps you need help?
Jorge Augusto Pessatto Mondadori, PhD
Sistema Fiep
CLAD, CLD
(2,832 Views)
I'm having trouble with the sensor and PID parts to determine the transfer function and what I've done is just making the pid program but there are still many errors, because I don't know in detail the PID method.
Yes homework. Yes I really need help to solve this problem
(2,827 Views)
Accepted by Nimass
In general, these forum are used to solve problems related hardware or software, if you don't share what you have done, what you need to do, nobody will be able to help.
Share you code
detail your requirements
explain which many errors still occur
with your given information, here is a link where you can find how to get the transfer function of such plant:
https://electronicscoach.com/liquid-level-control-system.html
but i don't believe it will help.
Also, do not expect anyone to do it for you. People help, but won't give your homework done. IMO, you should always try hard to be a better professional.
Sistema Fiep
CLAD, CLD
(2,823 Views)
