Additional NI Software Idea Exchange
LucD
Automatic (dynamic) generation of a Veristand Model from a VI
Status: Already Implemented
Functionality available with LVSV Batch Build VI.
Today I have a need that is a bit difficult to perform: I developped a soft that convert a xml file into a VI, but I'd like this soft to create a VeriStand model from this VI.
So it would be very interesting to be able to dynamically create a Veristand model in Labview, wheter thanks to an API or an invoke node, ...
I appears that for the moment the only way to do it would be to open the LVSV Dialog.vi by script.
Luc.
5 Comments
GregMo
NI Employee (retired)
If you look in the LLB that contains the LVSV Dialog.vi (look in <LabVIEW>/project/NI VeriStand/,) you will find a vi called "LVSV Batch Build.vi". This VI performs the same build that the dialog does, but does so programmatically.
NAKeel
Status changed to: Already Implemented
Nick Keel
Product Manager - NI VeriStand and Model Interface Toolkit
clendon.gibson@canrig.com
I have been trying "LVSV Batch Build.vi" in LabVIEW 2012 with Veristand 2012, and it does not work. It errors out with a reference type mismatch error.
Is there a fix?
PWoodward
This seems to have disappeared from the library. What is the new method in VS2023?
Certified LabVIEW Architect
PWoodward
For some reason I can't edit or delete my last post but I have found the function, not sure why I missed it yesterday.
