I believe that we should create and API for NI I/O trace so that customers with automated production lines can automate a report logging response to a failure In the case where a production line experiences a UUT failure, these customers could programmatically rerun the specific test that failed last, open I/O trace, start recording, test communication with a device, stop recording, and log the results when a failure is experienced. This could even be used with G or CVI code module, not just TestStand. That way if say the VI experiences a particular error after running subVI "testme", the API could be usted to start recording, re-run "testme", stop recording, and to generate a report. I understand that certain users only use IO trace occasionally, so an API would not be necessary for them, however, with customers who may have to trouble shoot numerous UUTs off of a production line, this could be a great help.
Shawn
Shawn S. | NIC
Instrument Driver/IVI PSE
