When using VeriStand with Source Control SW paths for Real-Time Sequences in the Stimulus Profile Editor need to be customized on every check out because it’s not possible to use a relative path for a Real-Time Sequence in a Stimulus Profile Editor.
Even if the Real-Time Sequence is in the same folder like a Stimulus Profile itself it isn’t found and the path has to be be adjusted.
So it would be awesome if it would be possible in VeriStand 2017 to use relative paths for a Real-Time Sequences in a Stimulus Profile Editor.
