Advanced Plotting Toolkit
No border for markers in line plot
I am crating plots with a lot of markers with the APT. Unfortunately the borders of the markers are always black, so when you have a lot of them each plot appears basically black, regardless of the chosen color. Is there any possibility, maybe even by manipulating the toolkit itself to get rid of the black borders or to at least make them the same color as the marker?
Below you can see the problem.
Here with APT:
This is what I am looking for, made with another program:
Can anybody help me?
(2,058 Views)
Can anyone help here?
(2,004 Views)
Accepted by PNB
I assume you are setting the point/marker styles according to - Line Plot — Advanced Plotting Toolkit
Have you thought about just making it a scatterplot? Scatter Plot — Advanced Plotting Toolkit
If you post the code you are using, you might get better help.
Craig
(1,995 Views)
You can use the line properties cluster and set the marker to invisible.
(1,987 Views)
Thanks for the hint with the scatterplot. It was exactly what I have needed here 🙂
(1,962 Views)
