ECU MC Tookit error 301072
ECU MC Tookit error 301072 ,    error :  parameter(s) out of range .
(3,010 Views)
Accepted by topic author WangWei357
Can you provide us with more contextual information about the error you are seeing?
  • Are you running an example VI or your own code? Example A2L?
  • Are you using the Demo ECU shipping example or a dedicated ECU?
  • Can you reproduce the error with an example VI using your A2L?
  • What hardware/software versions are you using?
  • Do you have a CCP/XCP Trace log file of the communications between your code and the ECU? Or a Bus Monitor log if you are running on RT?
The more information you can provide us, the faster we will be able to provide meaningful support.
Jeff L
(2,967 Views)
