Counter/Timer
Energy meter Lovato
Hello, I'm a Labview beginner. I need to acquire the pulse output signal from a Lovato DME D300 T2 device with a USB-6001. What is possible and how is the wiring done?
I thank in advance whoever wants to answer.
(2,064 Views)
You have to use the counter resource on PFI0/1 to count the pulses from your energy meter.
I would need to look into your energy meter to suggest the right connection. Maybe someone would else reply before me if they get the time.
Santhosh
Soliton Technologies
(2,032 Views)
If it can be useful at this link you can find the energy meter manual:
https://www.lovatoelectric.com/Download/I332IGB09_12.pdf
(2,028 Views)
Not easy though, below are the issues,
  • USB 6001 inputs are only 5V tolerant
  • Your energy meter has two outputs, but they require 10-30V for operation
Do you have an external 12V DC supply that you can use here and a bunch of resistors?
Santhosh
(2,016 Views)
Your device states 10-30V for operation but worth a try for the below connection
Using the output in PNP configuration, use NI MAX test panel to monitor pulse count,
Santhosh
(2,015 Views)
Thank you, you are very kind. I will try this setup by running the 5V energy meter. If this does not work, an external power supply with resistors must be provided. I ask you the kindness to post the scheme of this solution as well. Thanks
(1,999 Views)
