09-14-2021 02:57 AM
Hello, I'm a Labview beginner. I need to acquire the pulse output signal from a Lovato DME D300 T2 device with a USB-6001. What is possible and how is the wiring done?
I thank in advance whoever wants to answer.
09-14-2021 08:29 AM
You have to use the counter resource on PFI0/1 to count the pulses from your energy meter.
I would need to look into your energy meter to suggest the right connection. Maybe someone would else reply before me if they get the time.
09-14-2021 08:38 AM
If it can be useful at this link you can find the energy meter manual:
09-14-2021 12:07 PM
Not easy though, below are the issues,
Do you have an external 12V DC supply that you can use here and a bunch of resistors?
09-14-2021 12:16 PM
Your device states 10-30V for operation but worth a try for the below connection
Using the output in PNP configuration, use NI MAX test panel to monitor pulse count,
09-15-2021 03:02 AM
Thank you, you are very kind. I will try this setup by running the 5V energy meter. If this does not work, an external power supply with resistors must be provided. I ask you the kindness to post the scheme of this solution as well. Thanks
