02-01-2011 03:43 PM
Did you sort ths problem out? I need to do the simular thing.
Cheers
02-14-2011 04:33 PM - edited 02-14-2011 04:35 PM
Hi palmnz,
What specific question are you asking? Since you posted to this thread, I'll assume your issue is the same as the original poster's:
@9845567540 wrote:
I have a NI 6229 M series DAQ. I would like to perform a pulse width measurement using the same. There are two counters (ctr0 and ctr1) in the board. I would like to know if i can configure any PFI pin as a patricular counter's source / gate input??...
Yes, you can certainly do this. The syntax would of course be different depending on what development environment you are using:
Routing the source:
Routing the Gate:
If your question is different from the original poster's, please post to a new thread with more specific information about what you need to do. Note that if you're not configuring a Pulse Width task then the property used for the Gate input would be slightly different and would correspond to the task type.
Best Regards,
