Counter/Timer
configuring a PFI pin as a counter source/gate
Did you sort ths problem out? I need to do the simular thing.
Cheers
Message 11 of 12
(1,147 Views)
Hi palmnz,
What specific question are you asking?  Since you posted to this thread, I'll assume your issue is the same as the original poster's:
@9845567540 wrote:
I have a NI 6229 M series DAQ. I would like to perform a pulse width measurement using the same. There are two counters (ctr0 and ctr1) in the board. I would like to know if i can configure any PFI pin as a patricular counter's source / gate input??...
Yes, you can certainly do this.  The syntax would of course be different depending on what development environment you are using:
Routing the source:
  1. LabVIEW:
  2. ANSI C:
        DAQmxSetCICtrTimebaseSrc
  3. .NET
        CIChannel.CounterTimebaseSource
Routing the Gate:
  1. LabVIEW
  2. ANSI C:
        DAQmxSetCIPulseWidthTerm
  3. .NET
        CIChannel.PulseWidthTerminal
If your question is different from the original poster's, please post to a new thread with more specific information about what you need to do.  Note that if you're not configuring a Pulse Width task then the property used for the Gate input would be slightly different and would correspond to the task type.
Best Regards,
John Passiak
Message 12 of 12
(1,113 Views)
