12-12-2013 06:35 AM
i need help pleas
how to write external timer using ni usb 6251 code with labview to measurment pulse width about 5 msec
12-13-2013 04:31 PM
Hey edwad,
I am a little confused with your question. Do you mean..
1) You have an external clock that you want to use to take pulse width measurements.
Or do you mean
2) You want to measure the pulse width of a external clock?
12-14-2013 11:39 PM
hey connorM
I want to measure the pulse width of a external clock.
12-14-2013 11:42 PM
hey
i wont to measure pulse width using external clock with ni usb 6251 in labview
12-16-2013 06:50 PM
Here are three good examples that measure a pulse width of a signal.
https://decibel.ni.com/content/docs/DOC-25244
https://decibel.ni.com/content/docs/DOC-25245
https://decibel.ni.com/content/docs/DOC-25246
I hope these help
Connor
12-17-2013 12:08 AM
hey connor
i need to measure pulse width and if is big than 30msec i need count this pulse this process be attracted for 5 sec and stop.
the time must continue and be exact also if no pulse at all
i try to do it with ni usb 6251.
edward
12-18-2013 07:05 AM
The first example above will allow you to read in pulse widths until the stop condition is met. In the example the stop condition is the stop button OR an error in the DAQ occurs. You can add more stop conditions to this to match the functionality you want.
12-19-2013 07:52 AM
hey connor
i will try
thank you
edward
