Counter/Timer
nidaqmx.errors.DaqError: No DMA channels or USB Bulk Endpoints are available
I just bought the  USB-6423. and when I try to test the device by running the following example code on Github in VS Code python, I got the error "nidaqmx.errors.DaqError: No DMA channels or USB Bulk Endpoints are available", which I do not quiet understand. Could anyone help me to solve this issue? Much appreciated.
(339 Views)
According to USB-6423 Specifications, USB-6423 only supports Data Transfers mode of USB Signal Stream or programmed I/O. By default, DMA is used. You must set ci_data_xfer_mech to Programmed I/O (10264) or USB Signal Stream (I don't have the latest DAQmx driver installed to get the enum value. You might want to check with NI Technical Support).
(294 Views)
Thanks a lot! Is there a way to find the enum values from the driver than contacting the technical support, which I will do if not.
just trying to save time…
(261 Views)
