08-31-2011 12:09 PM
I want to create a function which takes only one vi path as input even though it has many controls and indicators . how is it possible.
For example i attached my code and the type of calling function i want . please explain
09-01-2011 01:16 AM
Hi
You can do that by attaching only the VI path control to the connector pane when the subVI is being created and not all the controls and indicators. Is this what you wanted or did you want something else?
regards
Flacon
09-01-2011 05:18 AM
Thank you kudos sir
09-01-2011 05:38 AM
HI
Thank you. However, you might wanna click on the kudos link as well 😄
Falcon
