DASYLab
how to set the input mode to differential for iotech personal Daq/3000
Hello all,
I'm currently using iotech personal daq/3000 for data acquisition from the accelerometer.
I got readings from the analog Input, while there seems to be no configuration for differential mode.
What I did is:
 hardware selection - personaldaq/3000:direct
 double click , then:
 Channel setup, there should be a differential mode selection, I guess. But its not there.
Many thanks,
Alan
(6,849 Views)
Accepted by Alan005
Have you reviewed the C:\Program Files\DASYLab 10.0\manuals\IOtech_DAQ_notes.PDF? Or the Hardware Help?
The hardware help section, Using Analog Inputs with DASYLab, has images to show how to do this.
Open the Driver Hardware Setup.
Click on the Analog Input Channels line, and then right-click to open Properties. This will display a dialog box that will allow you to set the properties.
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(6,844 Views)
