DATA AHEAD toolkit support Discussions
Licensing Terms and Wrapping Text
     Do I need to buy a individual license for XLR8 for each machine that I deploy my program too or do I only need one lecense that I'm develping on?
    Is there a way to set the Wrap Text attribute with XLR8? For example, I want a string like "The Little Brown Fox" to look like:
The
Little
Brown
Fox
--Ben
—Ben
Prevent your computer from sleeping programmatically!
Use Power Requests
Download from GitHub
Message 1 of 8
(7,595 Views)
Accepted by Ben_Manthey
Hi Ben,
deployment is free. If your code is built on a licensed developer machine you can deploy it without activating.
A developer license is valid for one developer and can be used on up to two computers.
As for the Wrap Text attribute: we actually just added this to our feature list for V2.1 due in late fall.
Currently, if you are working with a template, you can set the property in the file in MS Excel. XLR8 will keep the cell property when writing text to it.
Cheers
Peter
CLD | Alliance Partner | Web data storage and visualization | daq.io
Message 2 of 8
(6,017 Views)
Great, thanks, that's exacty what I needed to know.
I noticed that when I set a use the Font Area function to change a range of cells to Bold that it also Underlines them. How do I turn off the underlining?
--Ben
—Ben
Use Power Requests
Message 3 of 8
(6,017 Views)
Hi Ben,
it´s good to hear that we were able to answer your question before.
The constant underlining in the "Font Area" - function is a bug.
Thank you for this important notification!
If the developing works like scheduled this bug will be fixed in V2.1.
Hajo
Message 4 of 8
(6,017 Views)
Hi Ben,
underlining is fixed and wrapping of text supported in V 2.1 of XLR8.
Contact me to get the latest beta version. We will soon release it to the LVTN.
Peter
Message 5 of 8
(6,017 Views)
Peter,
Thanks, I’ll check it out on LVTN.
Are there any plans for supporting .xlsb files?
—Ben
Ben Manthey | +1 303 530 8555
—Ben
Use Power Requests
Message 6 of 8
(6,017 Views)
Ben,
sorry but we currently don't plan to support XLSB.
If you prefer a binary format over the XLSX you could go to the "old" XLS format.
-Peter
Message 7 of 8
(6,017 Views)
Peter,
OK, thanks.
—Ben
—Ben
Use Power Requests
Message 8 of 8
(6,017 Views)
