DIAdem
Change the default PowerPoint export template.
I've seen the older post about this, but there wasn't a clear solution. I want to replace the template found at C:\Program Files\National Instruments\DIAdem 2015\Resource\PowerPointTemplate.ppt with a template from my company. I am able to change the name of the file, copy the file, but it will not let me save anything in that folder since, I assume, it was locked by NI.
How can I go about accomplishing this?
Thanks.
(3,996 Views)
Accepted by Kevin_McG
Hi Kevin,
Try saving the PPT file to your desktop first, then copying the PPT file from the desktop to the Program Files... folder with Windows Explorer-- it should pop up and Administrator dialog that hopefully you can click <OK> on to approve the copy.
For many years now Windows has restricted access to the "Program Files..." folder tree to only allow Admins to make changes.  That's not a DIAdem lock, it's from Microsoft.
Brad Turpin
DIAdem Product Support Engineer
(3,968 Views)
That makes sense, and it worked perfectly.
Thanks Brad.
(3,966 Views)
