DIAdem
DIAdem Data Acquisition Example ?
Hello, I'm looking for an example in DIAdem to do a simple Data Acquisition.  All of the examples in DIAdem have simulated inputs but there looks like
there is a NI-DAQmx Driver Pallet that has several data acquisition blocks.  Does anyone have any examples I can look at ?  Below is an example
I pulled up with the NI-DAQmx Driver Pallet.
Thank You
(4,069 Views)
Hi RudyG,
First you need to define so called „Global Virtual Channels” in MAX (Measurement and Automation Explorer). All channels which you defined there can be chosen in “Driver-Inputs” for measuring data or “Driver-Outputs” for sending data to the hardware.
Then you can either load an example, select the “NI-DAQmx Driver” and drop it over an input block like “Random” – or define your own DAC scheme.
I hope this helps.
Greetings
Walter
(4,045 Views)
Hello Walter,
Where in MAX do I define the "Global Virtual Channels”.  I poked around and I can't seem to find the option.
Rudy
(4,024 Views)
Hi Walter
I found it.
Rudy
(4,023 Views)
