DIAdem
Portal.Refresh vs. Portal.Redraw
Hello guys,
hopefully an easy question: what is the difference between Portal.Refresh and Portal.Redraw?
We use mostly Diadem 2015, sometimes 2019, and I cannot see the different behavior in these commands...
But both commands are existing, therefore there should be a reason.
Greetings,
Vassili
(1,021 Views)
Accepted by Dia791
Hi Dia791,
Yes, there is a difference and the reason for both commands is performance.
Portal.Refresh recreates the whole Dataportal, independent how many channel croups, channels, and properties you have.
Poertal.Redraw only redraws the visible part of the Dataportal.
Greetings
Walter
(994 Views)
Walter,
thank you for the answer!
Means, Refresh makes more sense...
(983 Views)
