DIAdem
diadem,bode plot
Hi Brad,
Thanks for reply, i tried by that but still it's giving same error, i m sending u the tdm file which i have.
Nidhi
Message 21 of 24
(1,580 Views)
Well Nidhi,
I was able to reproduce the error you described with the TDMS file you sent and the old code I sent you, but when I implemented the "CLng()" change I mentioned the other day the error went away.  Try this code on your end:
Sub LoadTimeSubset(FilePath, DataPlugin, ChnStr)
  Dim DataFileHeader, Offset, Delta, Length, StartIdx, StopIdx
  StartIdx = 1 + CLng((R11 - Offset)/Delta)
  StopIdx  = 1 + CLng((R12 - Offset)/Delta)
  IF StartIdx < 1 THEN StartIdx = 1
  IF StopIdx > Length THEN StopIdx = Length
  Call DataDelAll
  Call DataFileLoadRed(FilePath, DataPlugin, ChnStr, "IntervalWidth", 1, eInterFirstValue, StartIdx, StopIdx)
End Sub ' LoadTimeSubset()
Brad Turpin
DIAdem Product Support Engineer
Message 22 of 24
(1,564 Views)
Hi Brad,
Thanx a lot,it works very fine.
Nidhi
Message 23 of 24
(1,535 Views)
Nidhi,
Hope your problem is solved. Do let us know if you have further issues.
Gaurav
Message 24 of 24
(1,470 Views)
