06-04-2024 07:30 AM
Hello.
I am using NI USB-6002 and I would like to know if a digital output configured as active drive can give 5V as "1" logic. Is it only possible to get 3,3V for "1" logic with active drive configuration?. I already Know the open collector possibility with an external voltage of 5V, but I am asking regarding the active drive output configuration. Is there any property which can be changed in LabVIEW for that?
Thanks a lot
Solved! Go to Solution.
06-04-2024 09:03 AM
Unfortunately, the hardware is not capable of active-drive 3.3V
06-07-2024 03:05 AM
OK,
I understand that the hardware is not capable of active-drive 5V.
Thanks a lot
