06-30-2017 10:48 AM
I am trying to calculate the resolution of my PXIe-4145 4CH Precision SMU, but Figure 2 in the PXIe-4145 Spec Sheet appears to have inconsistent labels on the x-axis. If all labels were in msec (not mixed usec/msec), it would map to a consistent logarithmic scale as the graph implies.
aperture (sec) | resolution (ppm) | notes |
0.010000000 | 1 | if graph didn't curve |
0.001000000 | 10 | |
0.000100000 | 100 | incorrectly labeled as 0.1 usec |
0.000010000 | 1000 | incorrectly labeled as 0.01 usec |
0.000001667 | 6000 | I think this is the max sample rate of 600kS/sec |
0.000001000 | 10000 | if graph continued |
link to spec sheet:
07-05-2017 10:29 AM
Yes, you're correct; the X-axis labels should be 1µ, 10µ, 100µ, 1m, 10m, and 100m. Thanks for pointing this out.
07-05-2017 11:42 AM
Hey Sam,
Thank you for bringing this to our attention.
I've filed a Corrective Action Request (CAR) to fix this in the 4145 specs (and also the 4144) specs.
Cheers,
Chris J.
Product Support Engineer
NI
