11-18-2024 02:08 AM
Hola,
He montado un chasis nuevo PXIe-1088, pero la tarjeta PXI-4065 no se configura correctamente y da error al instalarla.
Ya he reseteado la configuración y he actualizado los drivers.
¿Cómo podría solucionarlo?
Saludos.
11-18-2024 08:25 AM
This is a pretty low-level error, which typically indicates a hardware issue of some sort.
Suggested next steps:
11-20-2024 02:11 AM
Hi Tobias,
1. Has this PXI-4065 ever worked before? Can you try it in a different system?
No, it's a new team. I cannot test the card on another computer since they are old chassis (PXI-1036)
2. What software is installed on the system? Including both NI and Windows.
NI SW View report
Windows 10 Pro x64
3. What message do you get from Self Test? Reset Device?
The self test failed.
Status Code: -233900
Internal Hardware Error occurred in DMM hardware. Please contact National Instruments Support.
Reset Device, the same.
4. What result do you get from running a basic example?
If this were an official escalation, I would suggest uploading a MAX Technical Report, but that can contain sensitive information. Instead, I will ask if you could describe your system setup (or trim the generated HTML file of personal details and attach that to your reply.
Thank you for your response and I hope I can solve it.
11-20-2024 09:07 AM
Thank you for the additional information (and the switch to English - my Español is not strong).
At this point, I would recommend the following:
If none of these solve the issue, you are going to need to open a support request with NI for further assistance.
11-21-2024 06:09 AM
I've tried it and it still doesn't work.
I have replaced the PXIe 4065 with a similar one from another PXI 4070 chassis and it works correctly.
But I have tried to run an application in Labview 2017 and I get an error with the PXI-8513
Is the hardware configuration correct or is there some incompatibility in the installed hardware?
In this capture the PXI-4070 is mounted but the one I want to work is the PXIe-4065
11-21-2024 06:38 AM
Message error PXI-8513
11-21-2024 08:15 AM
If you are seeing issues with multiple modules, this is looking like a hardware configuration and/or compatibility issue at this point.
