Discovering and Imaging the Device
roboRIO 2.0 blinking status light
The more information provided, the easier it is for supporters and other members of the forum to res
Hi my name is Caiden from Team 9034
We are trying to get a roborio 2.0 to work and unfortunately we could not get it to work. The status light is blinking.
We tried using 2 different working imaged sd cards and did not work. We also read through the troubleshoot forum and tried everything and we even took it apart the roborio and blew it with compressed air and had the same results.
if someone could help us that would be great thank you!
Message 1 of 10
(667 Views)
What is the blinking pattern? is it a constant flash (no grouping?)
And to be clear, when you image the SD card using either BalenaEtcher or the Raspberry Pi imager you are using a .*img*.zip file as described here: https://docs.wpilib.org/en/stable/docs/zero-to-robot/step-3/roborio2-imaging.html ?
Message 2 of 10
(659 Views)
The blinking is constant and and yes we did use the .img.zip
Message 3 of 10
(623 Views)
Which imager are you using? (can you try the other one?)
Message 4 of 10
(620 Views)
We used 2 working as cards and we know there working because we tried both of them on a working roborio and we use balenaetcher
Message 5 of 10
(593 Views)
We have just been made aware that there is a crunched pin
Message 6 of 10
(592 Views)
I'm not sure whether or not a card can be moved between RIOs without re-imaging. I'll ask a hardware dev about that.
Can you try the RasPi imager (freshly image the card before inserting in the unit we're working on)?
Message 7 of 10
(581 Views)
TIL: Moving an SD card from one roboRIO v2 to another is supposed to work.
Can you double check (use a flashlight to help inspect) that there are no shavings in the SD card slot on the non-working unit?
Message 8 of 10
(574 Views)
We did use raspberry pi imager and tried but we used a flashlight and visually confirmed a bent pin
Message 9 of 10
(565 Views)
Ok, I sent you a direct message on next steps to deal with the bent pin.
Message 10 of 10
(559 Views)
