cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
pda daq
Hi!
Here my problem:
I would like to controle a group of gas sensors with a data acquisition hardware DAQ. This Daq has to be controlled by a pocket pc or pda because one of the most important things in this application is the easy mobility. We need that this card has at least 6 analog outputs (where the most important caracteristic is the presicion of output voltage) and 4 analog inputs.
I've been searching and i didn't find daq cards for pocket pc with more than 2 analog inputs. So if anybody knows a solution for my problem, like how to connect a DAQ for pc to a pocket pc/pda, i would be very grateful if he would say it to me.
Thank you!!!
0 kudos
Mensaje 1 de 3
6.380 Vistas
Hi nanospot in the following link you can find which cards we have for PDA data adquisition:
And The advantages you get from  LabVIEW PDA
Best Regards
Benjamin C
Principal Systems Engineer // CLA // CLED
0 kudos
Mensaje 2 de 3
6.364 Vistas
hi guys,
I've achieved to write in access database, but I want read data from the same table like a searcher, and that I can filter data and that they appear in the VI, somebody help me please!!
0 kudos
Mensaje 3 de 3
2.698 Vistas
