01-05-2013 03:23 PM
just installed the new FRC LabView, the registration number seems to be bum (it's telling me to call NI). I'm installed and running in eval mode, but need to fix this in the next week (have team PCs to load kit on in the first couple days of week).
serial number I have is a letter, 2 digits, letter, 5 digits.
Anyone else have this problem?
01-05-2013 04:15 PM
I'm having the same problem when I input my serial it says it is wrong but when I go online to get an activation code NI accepts my serial but NI Liscense Manager will not accept my activation code, why? I can also use evaluation mode.
01-05-2013 04:25 PM
We are having the same problem, We are being told that the activation code is not correct for the software, we can also run in evaluation mode.
01-05-2013 09:49 PM
There are two serial numbers on the FRC software.
There is a white card with a serial number next to a bar-code. This is not the real serial number.
The number is in tiny print at the bottom left corner of the colored printed card. It starts with an "S".
Phil.
01-05-2013 10:33 PM
Then why did NI recognize the serial I put in as the correct serial and give me an activation code that also did not work?
01-05-2013 10:43 PM
Try the registration number in the Getting Started with the 2013 FRC Control System document instead of the one on the envelope.
geoff
01-05-2013 11:09 PM
"Then why did NI recognize the serial I put in as the correct serial and give me an activation code that also did not work?"
Does it really matter?
Fact is, the number on the white card does not work, the one on the colored card does.
I'm sure there is some perfectly reasonable (but unfortunate) reason.
01-05-2013 11:45 PM
Thanks Philbot. The serial number on the yellow card worked. As GCS posted, it's the same serial number that is on the 2013 getting started guide.
01-06-2013 09:13 AM
Philbot, gcs, thanks much. The serial number on the yellow card and in the getting started doc is the correct one.
01-06-2013 05:35 PM
Sorry about the confusion everyone. The yellow card is the correct serial number. Is anyone still having issues with that number?
