12-08-2013 12:04 PM
whenever i try to run the remote controls program,on any sample program, labview crashes and i have to redo everything. i am running windows 7 and have the full version of labview.
12-09-2013 08:12 PM
Please verify the following:
Use the 'Help-About' tab to check that
Confirm that solid green boxes are on the following three items:
If any one of these is a light (shaded) green then right click on it an 'activate'.
Then exit LabVIEW and restart your computer.
If any of the versions were not up to date, then you'll need to update.
In some cases an entire re-install is your best bet .... check out these links to guide you:
https://decibel.ni.com/content/message/61863#61863
12-15-2013 05:02 PM
Thanks for the advice,
We have checked and it appears everything is current.
I guess we will try reinstalling.
For what it's worth, we don't have the Samantha wifi module because we don't plan to go to any competitions until next year.
We are a rookie team and all adivce is grealy appreciated. I must admit we are struggling to get traction here.
The Team
12-15-2013 10:47 PM
Go here to get an easy to print pdf with some very detailed installation instructions (page 3). Page 1-2 give you the guidance for getting 'Competition Ready with LabVIEW'. This is a 'printer friendly' version (slightly updated) of the posts I've been making regarding LV installs and such.
https://decibel.ni.com/content/thread/19824?tstart=0
We'v had LabVIEW crash on us a few times, but usually things are just fine. I look forward to hearing from you.
12-20-2013 06:19 AM
Actually, I tried that and it still was crashing. I decided to plug in another keyboard and it works just fine now. Thanks for your help!
