Feedback on NI Community
Unread Discussions
I'm not sure I would consider this a bug as much as I would consider it unexpected behavior.
When you are in a given board, there is a window that shows a select number of 'unread discussions'.
If you click on one if the discussions and read it, if you go to that board again, even after refreshing the page, it is still listed as an unread discussion.
Cory K
(8,858 Views)
Accepted by Cory_K
I haven't seen that problem.  Are you sure you're logged in?  Are you sure you've read all the messages in that thread?
(8,844 Views)
Ahh it looks like that was the issue. If you read all of the messages, then it leaves the unread discussions area. Nice catch.
Cory K
(8,822 Views)
The post levels have stayed the same which is
0 - 199 Member
200 - 1999 Active Participant
2000 - 4999 Trusted Enthusiast
5000 - 9999 Proven Zealot
10000 and up Knight of NI
The other things taken into account that change the color of the three bars are tagging, kudos received, accepted solutions and message views.  Those levels haven't been divulged at this time, but I could if there aren't any strong objections.
Laura
(8,787 Views)
0 - 199 Member
Laura
Laura,
Did you mean to post hereSmiley Happy
My original question was about forum functionality, not rankings.
Cory K
(8,773 Views)
Uh... very strange. Yes, that is where I meant to post!
(8,757 Views)
