Processor Compatibility for PCIe GPIB card
Does PCIe-GPIB card (Part Number: 778930-01) require an enterprise Intel Xeon processor or AMD Threadripper to run or any standard consumer range such as Intel Core i-Series & AMD Ryzen is sufficient ?
Thank You,
Clarence.
(2,743 Views)
Accepted by topic author stspg4u
Clarence, the PCIe-GPIB is compatible with devices that have a PCIe x1 bus available, per the PCIe-GPIB Specifications.
As you will see, it does not specify a specific processor model, brand or series for the hardware to receive power and communicate using said bus. However, I recommend ensuring the processor is sufficient for the operating system in which the driver will run. You can see the supported operating systems in the NI-488.2 driver's readme.
(2,656 Views)
The reason I asked because I haven't obtain the card yet as I needed to quote it for a client and build it together into their new industrial system PC.
Thanks Oscar, for clearing it up for me.
Best wishes, and Happy Holidays.
Clarence.
(2,628 Views)
