01-08-2016 02:21 PM
Instruction manual does not solve the problem. This forum even more.
01-08-2016 02:24 PM
01-08-2016 02:46 PM - edited 01-08-2016 02:49 PM
PrintSCR
NI
And
TDS....
01-08-2016 02:56 PM
01-08-2016 04:18 PM
What is the significance of the GPIB interface, it has a length of cable?
The advanced menu sets the parameters related to the length of the cable?
01-08-2016 05:21 PM
01-12-2016 04:46 AM
First : I was able to make a connection TEK(GPIB)-PC
To make a connection must be highlighted (active) field TALK / Listen address. Otherwise, the GPIB port works only send mode (hardcopy) and therefore it was not possible to connect. TEK non visible on the port.
Second:
Dear KNUTS you know everything perfectly.
Attached User manual see Page 3-191 to 3-194 show me the instruction description that field TALK / Listen ... it must be highlighted that the connection is active? OK ?
01-12-2016 05:09 AM
01-12-2016 06:10 AM
I am writing to you clearly that the instruction did not have written about it.
01-12-2016 06:25 AM
