01-18-2017 08:21 AM
i tried to find a solution for my problem in the forum, but i could not find any solution. I try to control the device via USB.
I can set and read the CR-options, but any other specific READ-command will fail with a timeout
VOLT:L1?
Read Operation
Error
VISA: (Hex 0xBFFF0015) Zeitüberschreitung, bevor der Vorgang abgeschlossen werden konnte.
Any SET-Command does nothing - no change in the display.
VOLT:L1\s120
I already tried to change the VI_ATTR_TMO_VALUE, but still no success.
Thank you for your help in advance.
best regards
hschenk
Solved! Go to Solution.
01-18-2017 11:38 AM
01-19-2017 05:24 AM - edited 01-19-2017 05:25 AM
Sorry, my mistake. CC, CR, CP, CV means the load options of the chroma device. (CC = constant current, CR = constant resistance etc.)
I can set the different options for CC (not CR as i mentioned in my first post - my mistake). Any other option will not work via USB control. I will test the commands with the VISA interactive control. I can identify the device via *IDN? and control the CC-Options, but commands like the following ones do not work, because of the timeouts. The newline command '\n' will be added automatically when i execute the command.
How can i fix the problen und what could be the error cause?
01-19-2017 06:25 AM
Everythin works fine. Manuel/commands of the device are insufficiently described.
