07-04-2014 06:46 AM
Hello !
I have a sbRIO9636 and the test instruments. I just want to connect sbRIO and Test instruments(with RS232).
I am trying to connect RS232 (9 pin) via serial ports..I also have Measurement & Automation Explorer (ver 5.1) to monitor and configure Serial/parallel connections.
The problem is that when I query, it looks like my device is properly recognized and no Error, but no data from test instruments come.
But when I connect the Test instruments directly to PC, NI Max shows COM 1 and can get the data from the test instrumnets.(shows like in pic)
Can you help me ? I don't know realy what to do?
Thank you!!!
07-04-2014 07:21 AM
@kellydog wrote:
Hello !
Pin 2 is the RX on the 9636. That should be connected to the TX of your instrument.
