LabVIEW Communications System Design Suite
Error -63101 in LTE Application Framework
NI Software
LabView Communications System Design Suite 1.1
LTE Application Framework 1.1
Windows 7 Enterprise
NI Hardware
USRP RIO 2943R
USRP RIO 2953R
Driver: NI-RIO 15.0
Problem Description
On Monday 29.2 I run the DL operation mode of the LTE Application Framework using the single device configuration (just one USRP RIO 2943, connected through a PCIe x4 module to a desktop Win7 computer) and I got the following error message:
I can not find a reasonable explanation for this since I am running the program directly "out of the box", the bitfile is pre-compiled from factory and I did not touch anything in the files. Furthermore, one month ago I was able to run it with no problem, using exactly the same device, cables and connectors​. Here is a screenshot of the erroneous code:
As you can see, the .lvbitx file (pre-compiled from factory) for the DL operation mode is being deployed.
Troubleshooting process
First round of adjustments:
  • ​Update all the pending updates of Windows 7
  • Look for critical updates via NI Update Service (nothing was listed)
  • Look for optional updates via NI Update Service (I installed all the ones listed but "FlexRIO 15.0" which I felt useless)
  • Re-run the LabView Communications installer in case something needed to be reinstalled
After these, I tried to run the program again and still the error is popping up.
In order check if this is a problem of the LTE App framework, I run the FM demodulator tutorial for USRP and this one worked, so I am afraid that there is some issue in the LTE App framework that escapes my understanding.
Second round of adjustments:
  • I uninstalled every single software of NI and installed everything again.
  • I tried to compile the bitfile my myself but I got an error regarding the license I am using (I am still using the one for students provided to KTH). I am attaching the logfile that the compilation process outputs.
  • I have tried connecting the USRP RIO 2953R
  • I have updated to LabView Runtime 2015 f2
  • I have installed NI-VISA Runtime 15.0
  • I have installed the FPGA Interface C API Generator 15.0 as this post recommended (even when I think it is not applicable in my case) http://forums.ni.com/t5/LabVIEW/Error-63101-when-running-FPGA-Interface-C-API-Generator-in/td-p/2162...
  • I have updated my Window 7 with the latest updates available in the Windows Updates Center.
Nothing has worked so far.
Here you can find screenshots  of MAX and the NI License Manager in case they are also useful:
Does anyone have any idea of what could be wrong in here?
Thanks in advance,
Adrian
Message 1 of 11
(6,049 Views)
Hi Adrian,
Can you confirm that this is a licensed copy of the Application Framework? In order to license, there is a sublicense agreement form with your purchase of the Application Framework. Once that form is filled out and signed, you need to email it to fpga.licensing@ni.com. Then the appropriate bit files should be sent back to you and you should be able to compile without errors.
Please let us know if you've gone through that process so we can help figure out the right next steps.
BeenCoughin
Message 2 of 11
(5,974 Views)
I have just got I full license from NI, you can see the difference in the License Manager entries in the images I am attaching. I got this licenses from a NI employee who is helping me with my project, so I did not purchased them and therefore I did not fill and sign that sublicense agreement that you mentioned either.
Both problems (the error popping up and my unability to compile the bitfiles my myself) are still there even with these new licenses.
I will forward your comment to my contact in NI shuld he know something about it. Here is a list with updates and new actions that I am taking to try to solve this problem:
  • The same error pops up when trying to run the 802.11 App framework
  • Getting a full license for both LabView Communications and LTE App Framework has not worked
  • I am installing the LabView FPGA Module 2015 SP1
Here I attach a picture of Labview FPGA Compile Worker 2014 should it is helpful. I also attach an updated XilinxLog resulting from the failing compilation process.
Adrian
Message 3 of 11
(5,959 Views)
UPDATE
I have just checked that I am able to compile the FPGA VI in the project Learn --> Getting Started --> Overview of the FPGA Design Flow --> "Deploying an Application on an FPGA".
Message 4 of 11
(5,944 Views)
Since you are able to compile a standard FPGA VI, I think that the issue is rooted in the Xilinx Licenses NI uses in the App Frameworks.
Have you tried downloading the Evaulations of the Xilinx Licenses?
http://digital.ni.com/public.nsf/allkb/9DE9BD509DF5876E86257E00005A69BB
Thomas C.
FlexRIO Product Support Engineer
Message 5 of 11
(5,894 Views)
I sent an email to fpga.licensing@ni.com and I got the same answer so I guess that this is the way to go. It seems that the links provided in http://digital.ni.com/public.nsf/allkb/9DE9BD509DF5876E86257E00005A69BB are no longer available. Do you know any other way to get these evaluation licenses for Xilinx Intelectual Property?
Adrian
Message 6 of 11
(5,822 Views)
Message 7 of 11
(5,819 Views)
Hello Adrikayak,
I am sorry that you had trouble with the link. It works well for me.
Can you please try to look at this link?
http://search.ni.com/nisearch/app/main/p/bot/no/ap/global/lang/en/pg/1/q/6V59QGPK/
If these links don't work, I think that your Firewall might be blocking part of ni.com.
Thomas C.
Message 8 of 11
(5,809 Views)
Hello tcap,
sotty I think I misexplained myself. I DO can access this link: http://digital.ni.com/public.nsf/allkb/9DE9BD509DF5876E86257E00005A69BB. What I can NOT do is accessing the links provided inside the linked webpage. Anyway, as I have explained before, I found the links searching in the Xilinx webpage and I am now in the process of getting the evaluation licenses. I will update the post when I make some progress.
Adrian
Message 9 of 11
(5,798 Views)
Hello all,
I got the evaluation licenses from Xilinx, but after checking thet they are only valid for two weeks and that I was not able to compile a new .lvbitx file even with them (I might skipped some crucial step), I  got full licenses for my NI software (those that do not expire ever). Here you can see how the NI License Manager looks like now and also the compilation final message:
This seems to have solved my unability of compiling a new .lvbitx file originated from "LTE FPGA USRP RIO 40 MHz BW DL.gvi". Nevertheless, compiling the new .lvbitx has not solved the original error -63101.
At this point I have no idea how to proceed, I firmly thought that compiling a new .lvbitx file would solve the error, but it does not. My only hope is that completing the process through fpga.licensing@ni.com will solve my problem. Should you have new suggestions, they are all welcome.
Adrian
Message 10 of 11
(5,719 Views)
