11-20-2015 11:18 AM
Dear Community,
I have witten a multi-rate diagram (Mapping_2_A) and another diagram (test) uses it as a sub-diagram but it's just simply an input port connected with Mapping_2_A. I have set the same data to the input ports of both diagrams as 1 + 1i,1 + 0i,0 + 1i,0 + 0i,1 + 0i,1 - 1i,0 + 0i,-1 + 0i,0 + 1i,0 + 0i,-1 + 1i,-1 + 0i,0 + 0i,0 - 1i,-1 + 0i,0 + 0i, any idea why that happens?
Many thanks!
Yi Chu
11-20-2015 12:01 PM
Hello Cy2008,
How are you running the simulation? How many iterations is LabVIEW Communications indicating that it is running?
I am getting 0 for the output of the both VIs.
11-20-2015 01:13 PM - edited 11-20-2015 01:13 PM
Hi tcap,
I am running the simulations directly under these VIs and I got 1 output from the 'test' and 0 from the 'Mapping'. I only run 1 iteration for these simulations. I am still using Labview Comms 1.0, maybe that is the problem? I will try run the same simulations on different machines and see if I get the same output. Many thanks!
Yi Chu
11-20-2015 04:16 PM
Hello Yi,
I am not running into the same behavior as you. When the simulation runs I always get a 0. I do run into a problem if I have 2 copies of LabVIEW Communications open (one for each VI). This prevents the simulation from executing. Please try it out on another computer.
I have attached a picture of my results.
11-23-2015 05:32 AM
Hi tcap,
I have tried them on two other PCs running Labview Comms 1.0 and got the same wrong results. I have attached my simulation settings. Am I getting anything wrong in these configurations?
Many thanks
Yi Chu
11-23-2015 10:31 AM
Hello Yi,
I was able to run your project in 1.0. I received the same results that you did. This indicates to me that this is a bug in 1.0 that was resolved in 1.1. Can you please upgrade to 1.1?
11-23-2015 10:41 AM
Hi tcap,
I figured that might be the problem, I am downloading 1.1 now. Thanks for the test!
Yi Chu
11-23-2015 10:43 AM
My pleasure.
Please let me know if 1.1 resolves the behavior.
11-28-2015 03:57 AM
Hi tcap,
I have downloaded 1.1 and it works ok, many thanks!
Yi Chu
12-10-2015 05:00 PM
Hello Yi,
Thanks for the update.
I am glad that you got it up and running. I let R&D know about the issue.
