If I keep them in the same project then I can run both interactive to debug. I inherited a project that has an RT.lvproj an FPGA project but how can I debug them since I can't connect both projects to same target, sbRIO 9067, All code is maintained in separate repos. For use in LVZ2019-24. 8 am not trying to cross LV versions. Just adding this in case answer depends on LabVIEW version. What are options to debug RT an FPGA simultaneously without combining projects? What are pros/cons of using separate projects vs one project?
