LabVIEW FPGA Idea Exchange
Allow access to multiple IO registers at once like on certain DIO modules
Status: New
I would like to have a feature to access several IO pin ranges to avoid programming this for a 9205 cRIO module:
With DIO modules like NI9403 you can program this:
Why not provide Mod2/AI0:31 in the above image? (With subranges like AI0:7, AI8:15,… similar to DIO module?)
6 Comments
r_good
How would you propose the 16-24 bit values on most AI modules be packed and presented to the node?  DIO modules are easy to perform what you are saying since you can pack the bits easily for reading and writing but it would not be as intuitive with AI.  It is possible but is it practical or necessary?
Knight of NI
Hi A_Tish,
when I use several AI inputs as depicted above I need them as an array. I also tend to connect sensors in groups of 8 to an AI module: 8 channels to read voltage signals, 8 more channels connected to shunts to read current signals.
I would like to have arrays, similar as for the DIO module, like AI0:7, AI0:15, AI16:23…
r_good
Hey Gerd,
THat actually sounds very practical.  I am in the same boat, but if it simply allowed us a fixed array[8] (or 16,32,etc) to input the values the BD would clean up nicely and it could still be easy to debug.
Just wanted to get the ideas going, but I agree the higher channel count modules (or any for that matter) are cumbersome and an array could work well.  How the background optimaized and handled it is out of my hands but it is a start.
crossrulz
Knight of NI
A_Tish, if you like the idea, be sure to give it a Kudos.  That is the metric that NI uses when looking at the Idea Exchange for features to implement.
GCentral
r_good
Sorry about that,
My browswer did not update my kudos.  I made sure it is in there now.
Thanks for heads up!
Jorn_Deruyck
There's actually a method node for the NI-9205 that should be a bit more efficient for the use case you've shown in your diagram, see below snippet. (the index counter is 5 bit and set to overflow at the increment node)
The only drawback is that it still can't be run from within a SCTL loop 😞
NI-9205 Channel ReadNI-9205 Channel Read
