LabVIEW FPGA Idea Exchange
hsinhsiang
Find FPGA Register
Status: Completed
Hey folks,
We agree this is a problem for all FPGA resources. Another example of a challenging situation is when you have DMA FIFOs and need to find the end-points on the FPGA and host that talk to each other.
We implemented this in LabVIEW NXG FPGA, however we likely won't implement this in LabVIEW.
Rahul
I hope the FPGA Register Function Could Add "Find Caller"....
12 Comments
AnthonV
Yes this is a very critical feature that is missing from FPGA.  From what I can see, there is no way to find all instances of where a register is used.  You can't even use text search on your diagram.  If I forget about a spot where I, say, put some test code that writes to a register, there is no way for me to search and find this.
We could extend this request to FIFO's and Memory's too.
National_Burritos
NI Employee (retired)
Status changed to: Completed
Hey folks,
Rahul
Rahul B.
AnthonV
Its a pity, as far as I know NXG isn't an option yet when using RT on CRIO, expansion chassis or PXI?
National_Burritos
Hey AnthonV,
Nope not yet but it is something we have a lot of people working on right now. If you come to the CLA summit in Austin in September, you might see something more tangible:)
Cheers,
Rahul
Rahul B.
AnthonV
Thanks for the invite, do you perhaps have a charity fund giving away complimentary flights to Austin from Africa?
But seriously we are quite anxious about NXG as we have such a huge code base in LabVIEW RT - we dont want to be left hanging while all your engineers work on NXG...
National_Burritos
Hey Anthon,
You're seriously in Africa? I don't personally know any of our customers there, that's cool! What country are you in?
In terms of having your huge codebase - if you have a project you would be willing to send us, we are always looking for more customer code to profile. Do you have something you could (via DM or e-mail)?
In terms of your comment of "left hanging" - do you mean in terms of not having requests responded to in a way you can leverage, or are you concerned about losing access to LabVIEW because of it getting replaced by NXG?
Best,
Rahul
Rahul B.
AnthonV
I'm based in South-Africa. Its the country at the southern end of the continent in case you were wondering. I've been to a couple of excellent NI-weeks but never to a CLA summit. I probably need to write the CLA exam first.
As for sharing code, that could be a problem because of confidentiality issues. We use LabVIEW to do the top to bottom coding for our range of mineral sorting machines.
What would be useful is a soft landing course on NXG for die-hard LabVIEW lifers.
hsinhsiang
Now I use this method to solve it.
You need get into the habit of programming...All register need be seen & named..
then use "Find and Replace.."
AnthonV
Thanks yes that will work. I just need to get into the habit of making the label visible and renaming it.
National_Burritos
Agreed on the soft-landing course! We have Core 1/Core 2 for NXG out, but not yet the other stuff since we haven't released it yet!
Rahul B.
