Number to Boolean Array and Boolean Array to Number along with array manipulation functions (index, replace, reverse) are commonly used methods in FPGA for doing bit manipulation on arrays of integers inside SCTLs. Not having access to these functions is prohibitive and results in having to write code like this:
This becomes very unwieldy when dealing with arrays of 20+ elements. If Number to Boolean Array and Boolean Array to Number are truly no-op elements, then they (along with basic array manipulation nodes) should be added to the list of supported nodes inside for loops inside SCTLs.
