Initially I looked around for my previous idea here: Selecting between two I/O refnums not allowed because I thought it was the same and intended to post a comment to that, but I see that was a bit more specific.
This seems like a more allowable case - why is A forbidden and B perfectly ok?
A:
Select node in SCTL
B:
Case Structure to choose between two values based on boolean input
Here A is forbidden (at Intermediate file generation - so perhaps this would help: Unsupported nodes inside for loop within SCTL should result in a broken VI (NXG != Already Implemented really...)) but B is compiled with no problem. I really don't see why Select of two integers is different to a Case Structure with two integers input, a boolean case selector, and an integer output from the two inputs...
As an idea rather than a rant, I'd like A to be possible.
