LabVIEW FPGA Idea Exchange
--thatguy
Logic Operators and Arrays
Status: Completed
Included with LabVIEW FPGA 2012.
It would be nice to be able to use logic operators on arrays in Single Cycle Timed Loops.
  17863i0D7A4F514670B8AB
4 Comments
Lars.B
Adding to that, it would also be very nice when you can e.g. compare two arrays directly with =.
And not have a similar picture as in the left.
In former LV-versions this was by the way no problem... interestingly a step backward.
Dragis
Lars, I don't believe LabVIEW has ever supported these nodes inside the SCTL, although it does outside. Did you see differently?
Dragis
Status changed to: In Beta
Dragis
Status changed to: Completed
