LabVIEW FPGA Idea Exchange
Terry_ALE
P2P to GPUs
Status: New
P2P is a very useful technology for sharing data between NI targets.
Could this be provided for GPUs?
ALE Consultants
6 Comments
Nikn
NI Employee (retired)
Hi Terry,
Looks like you might have already seen the post
Are you looking for something beyond it? Can you describe your use case for me to understand how NI can support you better.
Kiran
Kiran Nagaraj | Principal Product Owner | LabVIEW R&D
Terry_ALE
Hi Kiran,
The posted code is older and there is a concern for future support.  There is no specific need although customers do like the idea of offloading some processing on a GPU which has software level compile times (as opposed to the FPGA).
ALE Consultants
nanocyte
I need this right now. Basically, I need a low latency path between the GPU and the FPGA that doesn't bother the CPU. This also gives you more determinism and saves you CPU resources.
https://developer.nvidia.com/gpudirect
https://blog.zhaw.ch/high-performance/2019/10/03/direct-communication-between-fpga-and-gpu-using-fra...
Terry_ALE
nanocyte
This warning scared me: Note: FlexRIO no longer officially supports x86 systems. See NI_FlexRIO-16.0.0_P2P_GPU_Driver/README.txt for more information.
Terry_ALE
I assume that x86 means 32-bit systems and x64 means 64-bit systems.
See http://net-informations.com/q/mis/x86.html
ALE Consultants
