LabVIEW FPGA Idea Exchange
adalyn
Parallel loop support
Status: New
Parallel loops are supported by LabVIEW but not LabVIEW FPGA, this requires us to copy/paste the same blocks multiple times to make them run in parallel.  I would like to see the ability to use parallel loops on FPGA targets as FPGAs are very well suited to this style of programming and the current copy/paste parallelism hinders this.
8 Comments
Wolfgang_Z.
NI Employee (retired)
This would be a big advantage to run reentrant subVIs parallel without copy the subVIs.
James_McN
This is the biggest pain with high channel SCTLs and fully support this! I tried to suggest it as loop unrolling but this description and syntax would make more sense
James Mc
CLA and cRIO Fanatic
My writings on LabVIEW Development are at devs.wiresmithtech.com
clicks
The most useful programming structure on FPGA is parallel execution. I do not understand why this pretty nice notation with "parallel for loops" is available on the host system but not on the FPGA. I have so many cases where the notation would perfectly fit but I have to write it all out and when changing the array size I have to go through all code. NI, you need to give a very good reason to refuse this structure on FPGA or are you just too lazy to implement it 😉 (or do you get payed by the miles of wires we are drawing on the vis?).
programming languages are about how nicely you can express a code!
MaxJoseph
I would love this feature!
The best workaround I have at the moment is programming what I want in VHDL and then making an IP block to implement it in LabVIEW. But if I have already programmed up the maths in LabVIEW then I cannot use this work in the VHDL, I have to port the code to VHDL before building the IP.
CLA - Kudos is how we show our appreciation for comments that helped us!
Austin-Downey
It looks like I will have to learn how to program HDL blocks and pull them in as this in not currently supported.
I asked the same basic question here. https://forums.ni.com/t5/LabVIEW/Automating-Parallelization-in-LabVIEW-FPGA/m-p/4185946?profile.lang...
Terry_ALE
This is similar to what LabVIEW FPGA IP Builder supported pre-2020: https://zone.ni.com/reference/en-XX/help/371599P-01/lvipbuilder/lvipbuilder_tutorial/
See 2020 release notes where it was deprecated: https://www.ni.com/pdf/manuals/374737l.html
ALE Consultants
Austin-Downey
Any idea why this was pulled out? I asked a similar question at the link below, it looks like that would have been a good way to solve it. I wonder if it is worth back-tracking to 2018 for?
https://forums.ni.com/t5/LabVIEW/Automating-Parallelization-in-LabVIEW-FPGA/m-p/4185769#M1210561
Terry_ALE
I would not back-track because then you have no upgrade path.
ALE Consultants
