The LabVIEW FPGA module has supported static dispatch of LabVIEW Class types since 2009. This essentially means all class wires must be analyzable and statically determinable at compile-time to a single type of class. However, this class can be a derived class of the original wire type which means, for instance, invoking a dynamic dispatch method can be supported since the compiler knows exactly which function will always be called.
http://zone.ni.com/reference/en-XX/help/371599H-01/lvfpgaconcepts/fpgaclassesinvis/
This is not sufficient for many applications. Implementations that require message passing or other more event oriented programming models tend to use enums and flattened bit vectors to pass different pieces of data around on the same wire. All of this packing and unpacking can automatically be handled by the compiler if we can use run-time dynamic dispatch to describe the application.
We call for the LabVIEW FPGA module to add support for true run-time dynamic dispatch to take care of this tedious, annoying, and down-right boring job of figuring out how to pack and unpack bits everywhere. Whose with me?
