LabVIEW FPGA Idea Exchange
PIE5-66945.0
Support Malleable FPGA VIs With the Desktop Execution Node
Status: New
Malleable FPGA VIs import into the Desktop Execution Node with the same datatype as the FPGA VI's "malleable terminal".  The Desktop Execution Node does not mutate the input type to match the "malleable terminal" of the FPGA VI.  As a result, host VI test benches cannot iterate Type Specialization Structure cases in the malleable FPGA VI.
The "anything" input to this Assert Structural Type Match node is an I16, which breaks this case against an I16, which is the "malleable terminal" of this VI.
The Desktop Execution Node only sees the I16, and coerces other datatypes.
IMO the compiled Type Specialization Structure case is a critical unit test, which depends on the data type of the control wired to the "malleable terminal", so this is a critical limitation of the Desktop Execution Node.
I think the intended use-case for the DEN is to hook into an FPGA VI that's in a loop, and if so, the inputs to the malleable VI are selected by the calling VI.  So, maybe this isn't a limitation of the DEN itself, but of the DEN workflow.
Thanks for your consideration,
Steve K
1 Comment
PIE5-66945.0
* "...which breaks this case against an I32..."
