09-21-2014 10:14 PM
Buen dia, al compilar el LIFA_BASE me arroja este error. No se que puedo hacer.
C:\Program Files\Arduino\libraries\RobotIRremote\src\IRremoteTools.cpp:5:16: error: 'TKD2' was not declared in this scope
int RECV_PIN = TKD2; // the pin the IR receiver is connected to
10-15-2014 02:24 AM
Me marca el mismo error al compilar y no encuentro ayuda en la web, que hacer?
10-15-2014 08:17 AM
I searched through all the other posts about this error and it seems that the issue is usually that they are not using the correct version of the Arduino IDE. The latest version of the Arduino IDE that works with LIFA is 1.0.5.
02-12-2015 05:49 PM
Error:
C: \ Program Files \ Arduino \ bibliotecas \ RobotIRremote \ src \ IRremoteTools.cpp: 5: 16: error: 'TKD2' não foi declarado neste escopo
É verdade, estava com esse problema, pois estava usando a Versão 1.6.0, então baixei a versão 1.0.5 e funcionou direitinho.
02-18-2015 09:19 AM
Hola,
Simplemente cree una carpeta llamada Backup_RobotIRremote ( para no borrar la carpeta original ) y movi( cut & paste ) la carpeta RobotIRremote entera a esa nueva, porque no necesito para nada su contenido.
Puedes simplemente borrarla si no la necesitas.
Ve a Program Files\Arduino\Libraries y has como prefieras.
Compila sin problema ninguno.
02-18-2015 12:12 PM
Solution is:
1) Go to computer -> go to (C:) -> program files (x86) -> Arduino -> libraries -> RobotIRremote
2) Move files IRemote.cpp, IRemote.h, IRemoteInt.h, IRemoteTools.cpp and IRemoteTools.h to the desktop or somewhere out of primary Arduino map (you can even delete them but rather not maybe you will need those files)
Note: If Arduino map is not in program files (x86) than it's where you have saved it.
Have fun!
01-15-2016 09:47 AM
Here you have the solution to your problem.
https://decibel.ni.com/content/message/125048#125048
If you solve the issue, please check the reply like a right answer.
