07-07-2015 02:59 AM
Hi there,
I'm quite confused choosing the right version/license for my needs.
Does LINX work with the 2013 Student Suite version? Where can i find a table which shows all available versions and the differences between them?
Thanks a lot
Stein
07-07-2015
07:25 PM
- last edited on
04-16-2024
08:33 AM
by
Content Cleaner
FYI
LINX is developed in LabVIEW 2011 so that it can be used in LabVIEW 2011 or anything newer (if it's 32-bit). I've run it on 2011, 2013, and 2014.
LINX is intended for Non-Commercial applications. Hence most people using LINX are using the Student Version of Labview.
See: <https://www.labviewmakerhub.com/doku.php?id=get_labview> for information about the two different versions of Labview that are available for Non-Commercial applications.
For a source for the Home Bundle See: <https://www.digilentinc.com/Products/Detail.cfm?NavPath=2,719,1456&Prod=LABVIEW-HE>
hrh212
