At the moment, there is a small development problem with dynamically launched VIs (via the Asynchronous Call method). They are not recognised as dependencies during the deployment process, so the code can't be run effectively in development mode via the run arrow (those VI's will return File Not Found errors).
A simple fix for this would be to be able to mark VI's as "always deploy" in the project window.
