05-03-2017 04:16 PM - last edited on 05-04-2017 05:41 PM by karina.barles
I am running LabView myRIO 2016 and the Lego Mindstorms NXT on Windows 10. The connection to the Mindstorms is through Bluetooth however I see the same behavior with USB connection as well. I have a simple VI which has a counter and displays the value from the sonar sensor. When I run the VI it pauses (freezes) every few seconds for a couple of seconds and then continues. I see in the task manager that during that time the CPU usage for LabView is zero. I don't see any other tasks using more CPU during that time. Any ideas what is going on?
05-04-2017 11:14 AM
Hi aodematt,
Does this VI has timing limitations? In the help of this VI it doesn´t say anything about it? What happens if you increase the the "wait" time or if you delete it? Does it make any difference?
05-04-2017 01:30 PM
I see the same problem if I increase the wait time. I changed it to 1 sec and it freezes for about 2 seconds every 5 to 6 seconds. It might be a Windows problem with accessing Bluetooth or USB however I don't know how to tell.
05-05-2017 11:20 AM
Yeah it looks like...can you test it in another machine?
05-05-2017 11:30 AM
Not that easy but will try. I tried downgrading to LV2015 and I have the same problem. Even more a reason to investigate Windows.
05-08-2017 09:20 AM
Yeah it sound like a windows issue.
05-15-2017 11:51 AM
Tried another computer (Low performance) with a Celeron and only 2GB of ram. I am seeing the same problem. Will try a different more powerful laptop this week.
05-16-2017 08:52 AM
It sounds like a good idea
05-25-2017 06:06 PM
Installing it in new machine which had Windows 10 only and no other applications worked. This makes it look like a Windows problem.
