LabVIEW in Finance
Applying the Technology
Among the NI tools, LabVIEW FPGA and IEEE-1588 can be used in Finance for a number of problems.  Certainly there are other areas such as LabVIEW for Windows ability to produce parallel
1. An FPGA based network card used to process and generate network traffic.
2. An FPGA or bank of FPGAs as coprocessors.  FPGAs can process certain algorithms up to 1000 times faster than CPUs.
3. An FPGA based network card with a IEEE-1588 card to timestamp incoming and outgoing data for latency measurements.
4. Peer to Peer with FlexRIO PXIe cards can be used to expand out for multi-FPGA solutions.
ALE Consultants
(6,657 Views)
High Speed Serial Cards give you 10 Gigabit (SFP+) interfacing right into an FPGA
http://www.ni.com/white-paper/52257/en/
ATCA-3671 gives you even more network interfacing into a four (4) FPGA solution
http://sine.ni.com/nips/cds/view/p/lang/en/nid/213789
ATCA-3671 main specs:
4 Virtex-7 690T FPGAs with a combined 14,400 DSP slices
64 GB onboard DDR3 DRAM
4 ATCA IO (AIO) module slots with both analog and high-speed serial IO options
Up to 1.5 Tbps external connectivity available through PCI Express, SFP+ and QSFP
ALE Consultants
(3,236 Views)
