06-30-2024 12:57 AM - edited 06-30-2024 01:13 AM
LabVIEWで韓国語を表示することはできますか?
Windowsの言語設定で、韓国語を追加しましたが何も変わりませんでした。
添付ファイルでは、ネットから文章をコピペしています。
中国語は最初から表示されていました。
韓国語を表示させるにはLabIEW側で設定が必要でしょうか?
どなたか分かる方がいらっしゃいましたら、よろしくお願い致します
Community Edition
Version 21.0.1(32-bit)
06-30-2024 11:41 AM
To change the language of your LabVIEW environment you have to uninstall your current version and then re-install LabVIEW in your preferred language. However, 64-bit versions are only available in English.
You can find more details here.
07-01-2024 07:30 AM
Thank you for your suggestion.
However, I would like to use Japanese and Korean at the same time. Will I be able to use Japanese when I install the Korean version?
07-01-2024 12:27 PM - edited 07-01-2024 12:28 PM
Unfortunately I don't think that's possible with a single installation. But you could try downloading two different installations: one in Japanese and the other in Korean, both in the same machine/computer and see if that works out.
07-07-2024 11:39 PM
I understand that it's difficult to do everything with one piece of software.
I'll consider whether to install both Korean and Japanese.
Thank you very much for everything.
