AO 1Sam vs Configure Timing
Having a AO task, which should allow one to change dc during generation: You can write a 1D array DBL with Mul Chan 1 Sample Write to generate varying DC levels when configuring no timing at all, fine. BUT, I need to be able to Start the Task here using the actual Start vi. This means I have to write the buffer before starting with autostart off, which means I have to configure timing. BUT I can't figure out how to configure the timing, in order to write dc with a single sample.
Is it possible to generate dc, writing one sam per channel with a task that starts with predefined levels using Start Task.vi?
Actor Framework
(224 Views)
That's essentially an on-demand software-timed task. There is a shipping example for that.
Just omit the DAQmx Configure Timing VI will do.
(186 Views)
Yes, my question is, if one can mimic the 'omit the DAQmx Configure Timing VI', I think this means I would have to Configure a '1 Sample Mode' using the Configure Timing.
Is not configuring timing the same as 'Simultaneous Analog Output Enable'?
Actor Framework
(173 Views)
If you don't configure sample clock timing, the task will use on-demand mode by default. If you set Simultaneous Analog Output Enable to true when using on-demand timing, it is the same as using a finite sample clock timing with 1 sample point, but without using the limited hardware timed task.
(139 Views)
